NEW: Camburg Raptor 1.25 Uniball Upper Arms
Discussion in 'Camburg Engineering' started by [email protected]_Camburg, Nov 19, 2013.
  1. Sales_@_Camburg
    [email protected]_Camburg Full Access Member
    70
    108
    Oct 31, 2013
    Huntington Beach, CA
    We also released these a few weeks ago as well.
    "We now have available for the Ford Raptors our 1.25" uniball upper arms that use polyurethane bushing versus heims like on our 1.50" uniball versions. This keeps the cost down with less maintenance. Also by using a smaller uniball you're able to use the factory offset wheels with larger tires."
    For more info click HERE.
    - Sales @ Camburg
    [​IMG]
    [​IMG]
    dkfc13 and MTUH3 like this.
  2. BIRDMAN
    BIRDMAN Birdministrator Staff Member Admin
    12,923
    6,143
    May 16, 2010
    Boston
    So are these the same length as stock or longer?
  3. Sales_@_Camburg
    70
    108
    Oct 31, 2013
    These replace the stock upper arm to correct caster and allow for more wheel travel. If you want/need an arm with more adjust-ability our 1.50 uniball arms have 7/8" heims you can adjust.
    - Sales @ Camburg
    MTUH3 likes this.
  4. vanilla_gorilla
    vanilla_gorilla FRF Addict
    2,520
    1,000
    May 25, 2011
    NorCal (Sacramento)
    Again, another novice question, but how does the UCA give/allow more travel?
  5. ntm
    ntm Full Access Member
    45
    886
    937
    Sep 11, 2011
    Alberta, Canada
    The stock outboard ball joint on the uca binds at full droop. You get a little more droop travel with an aftermarket uniball arm.
    vanilla_gorilla likes this.
  6. vanilla_gorilla
    2,520
    1,000
    May 25, 2011
    NorCal (Sacramento)
    Ah, got it and makes perfect sense...thanks.
  7. AlpineM3
    AlpineM3 Full Access Member
    135
    30
    Jun 27, 2013
    Question - How much more droop is obtained with a uniball uca would you say?
    Sent from my HTC6500LVW using Tapatalk
  8. Sales_@_Camburg
    70
    108
    Oct 31, 2013
    Really it depends on what aftermarket coilover you're using with the arms and their dimensions. The FOX 3.0 coilovers give you about 1" more travel since they are around 1/2" longer than stock. It's around a 2:1 motion ratio, 1/2" at the shock is 1" at the wheel.
    - Sales @ Camburg
  9. Sales_@_Camburg
    70
    108
    Oct 31, 2013
    Did an install today so I made a point to shoot a couple pics of it installed. On this truck we just made the perch adjustment to the OEM FOX coilovers and installed our arms with 37" tires and Method 17" NV wheels. Turned out really clean for a mild build.
    - Sales @ Camburg
    [​IMG]
    Gus00SVTL and vanilla_gorilla like this.
  10. vanilla_gorilla
    2,520
    1,000
    May 25, 2011
    NorCal (Sacramento)
    Lets see more pics, please....
Share This Page
