NEW: Camburg Raptor 1.25 Uniball Upper Arms
Sales_@_Camburg
Huntington Beach, CA
We also released these a few weeks ago as well.
"We now have available for the Ford Raptors our 1.25" uniball upper arms that use polyurethane bushing versus heims like on our 1.50" uniball versions. This keeps the cost down with less maintenance. Also by using a smaller uniball you're able to use the factory offset wheels with larger tires."
For more info click HERE.
- Sales @ Camburg
Sales_@_Camburg
Sales_@_Camburg
These replace the stock upper arm to correct caster and allow for more wheel travel. If you want/need an arm with more adjust-ability our 1.50 uniball arms have 7/8" heims you can adjust.
- Sales @ Camburg
AlpineM3
Question - How much more droop is obtained with a uniball uca would you say?
Sent from my HTC6500LVW using Tapatalk
Sales_@_Camburg
Sales_@_Camburg
Really it depends on what aftermarket coilover you're using with the arms and their dimensions. The FOX 3.0 coilovers give you about 1" more travel since they are around 1/2" longer than stock. It's around a 2:1 motion ratio, 1/2" at the shock is 1" at the wheel.
- Sales @ Camburg
Sales_@_Camburg
Sales_@_Camburg
Did an install today so I made a point to shoot a couple pics of it installed. On this truck we just made the perch adjustment to the OEM FOX coilovers and installed our arms with 37" tires and Method 17" NV wheels. Turned out really clean for a mild build.
- Sales @ Camburg
