Lower Control Arm size and torque.
R@pt0r
Does anyone know the size of the lower control arm bolt? I also read that the torque spec is 400ft/lb and if you don't get it tight enough it will clunk.
I took a shot at doing the mid perch adjustment yesterday, but bailed and put it back together when I realized I couldn't do it without removing the lower bolt. I though I could pull the coilover out of the top mount and forward to get the spring compressed and off. I couldn't. Then I talked to my neighbor yesterday and he said he did a leveling block on his non-Raptor F150 with just a cresent wrench on the lower bolt. (My cresent he borrowed wrench no less) .
So I'm thinking I'll try again today to save face!
---------- Post added at 10:43 AM ---------- Previous post was at 10:34 AM ----------
Nevermind. Karma, I have the 27mm and 30mm sockets. I'm doing it.
ICONRep
Riverside, CA
I believe from the factory the lower arm TS is at 260ft/lb front bolt / 350ft/lb rear bolt and the lower shock bolt is just over 400ft/lb (406ft/lb??).....there may be reason for it to be different but that is OE call outs if I remember correctly off the top of my head.
Edit - Here is the Torque Spec Thread link here on FRF
http://www.fordraptorforum.com/f39/torque-specs-11451/
R@pt0r
R@pt0r
Thank you, looks like 406ft/lbs. I have a three foot 1/2'' drive breaker bar that should work.
treypal
Lord of the Raptors
Riviera TX
FYI it's 27mm and 29mm. Not 30.
I pull mine quite a bit. Just run em back on with the impact as right as they will go. I paint mark across the nut and threads. They never back off.
*disclaimer. Opinion. If your stuff falls apart. Not my fault.
R@pt0r
R@pt0r
Done. The bottom bolt wasn't as bad as I thought, but I did hurt my back and foot getting the passenger side bolt loose. The adjustment raised the front about 1" or so. A few things I noticed. First, When putting the struts back together get the alignment between the top mount and the bottom mount correct before loosening the spring compressors. You can't do it afterwards. Also make a note of the alignment plate orientation. Last, I noticed that the "fox racing" stickers were upside down on the passenger side. Probably bacause the shocks are not left/right specific so one has to be inverted. Of course I fixed it.
