rtmozingo
I edited the tire pressure settings using FORSCAN. You set what the placard pressure should be, and it calculates when the low pressure light should come on (seems to be 75% of setpoint). I set the front tires to 33psi and the rears to 30psi, so I shouldn't get an alarm prior to 26psi. You can see that strangely, only my front left tire is alarming, even tho it should have the same setpoint as the front right, which is not alarming. It appears to be a bug...anyone have this, and if so, were you able to fix it?
