GEN 2 Leveling Kit?
nbd13
Charlotte MI
Hey,
What is everyone using for a leveling kit? Just got new rims and tires and the place I got them was going to do a leveling kit, but the kit he ordered he said it was junk and there where no other “good” options for leveling kits?
Need help as I would like this truck leveled.
Thanks
N
nbd13
Charlotte MI
Nick@Apollo-Optics
These are high quality and have been around/tested to last?
Thanks
We’ve been offering these since late 2016 when the Gen 2 Raptor first debuted.
If you have a 2017-18 truck, we recommend the 2.25” for level stance.
If you have a 2019 truck, we recommend the 1.5” for a level stance. 2.25” will sit slightly nose high.
N
nbd13
Charlotte MI
Thanks and no issues with these. I have a 2019 truck.
Thanks
N
nbd13
Charlotte MI
Wouldn’t these make it a stiff ride?
Anything just to level without affecting ride quality?
Thanks
Nick@Apollo-Optics
Thanks
They add preload to the spring to raise the height. You may notice a slightly firmer ride, but with only a 1.5” increase in height, the impact is minimal.
You could also look into Eibach spring replacements that raise the truck 1.73” overall.
If you want to raise the front and have zero ride impact, your only option is full replacement shocks. They’ll be available later this year from Fox. Retail pricing for the front shocks (pair) is $3799.95.
greatone99
ma
on the 2019 live valve shocks ,is the install procedure the same on the front as the 17 and 18s ,meaning if im carefull can I do it without removing the shock from the truck ,compress the spring in place , and carefully tap the lower portion up to make room for the 1.5 perch collor ??? if so I def want a pair for my 19
