ogdobber
- Joined
- Feb 9, 2017
- Posts
- 1,163
- Reaction score
- 1,591
So im aware there is a recall for certain 2011-2012 6r80 transmissions... however mine doesn't fall into that (mine is a late 2012) besides, the recall is for a sudden downshift which mine has never done.
However... yesterday i did run into a problem. Pulled into a parking lot to turn around and when i couldn't complete the uturn, shifted into reverse and the rear camera didn't turn on? Looked down to to see if i was in R and i was... however on the dash the R was white...anyways nothing no reverse...couple revs and she slammed into reverse and a wrench came up on the dash.
I plugged in my code reader and i got p0705 (transmission range sensor) which on the 6r80 is part of the leadframe.
The fix- called first dealership and they said $200, thankfully they closed before i went there because my local Ford dealer was only $130 this morning.
2 hours later, 8 quarts of tranny fluid and a new filter she is shifting better than ever.
Also another thing to note, my transmission is now running (at least) 20 degrees cooler. It was high 90's today and the hottest tranny temp i saw was 180
Install was simple, drop pan, 11 t30 to pull valve body and 6 t27 for the leadframe.
I highly recommend replacing your leadframe to the new one ford has released even if everything *seems ok. 180 degrees on a hot summer day!
Edit-see below
*Note*
Low temps where seen because i put the thermo valve in upside down so the fluid constantly flowed to the cooler. Had to drain and redo [emoji23]
Below is proper orientation
Edit-see below
*Note*
