Instrument cluster screen loosing power and rebooting
ajitpal toor
2019 ford raptor upgrade fog light and Phoenix radio screen
I recently facing the problem with the the instrument screen loosing power
Everything is working fine but the power is going in and out while truck is running.any idea it’s might be t harness Phoenix radio making a problem
someone else on here had this kind of problem. I’m not sure if the Phoenix audio unit would contribute to this.
WILDCAT19
South Carolina
I’m having the same problem...taking my truck back to dealership on Monday. Was told the entire dashboard may have to be changed out. I’ll post more when I get details. My dash goes in and out and sometimes only halfway comes back. Super frustrating when driving down the highway and your entire onboard system shuts down.
ajitpal toor
ajitpal toor
Please let me know that what I’m thinking to do
WILDCAT19
South Carolina
Dealership ordering new cluster dash. I have 2900 miles on my 2019 802A truck...complete BS. I hope they don’t tear anything else up replacing my dash. Said it takes 3-4 business days to get the part and 2-4hrs for install.
ajitpal toor
ajitpal toor
  1. Dealership ordering new cluster dash. I have 2900 miles on my 2019 802A truck...complete BS. I hope they don’t tear anything else up replacing my dash. Said it takes 3-4 business days to get the part and 2-4hrs for install.
    same problem. dash cluster replaced under warranty
    It is not due to Phoenix radio?Do you Have the Phoenix radio in your truck ?
Stratia69
Belton, TX
Still An issue for you? Mine started at 1600 miles, thought it was a the bad media hub, swapped and was good for a month. Then all started again. I too though it was an accessory issue since mine started after installing my dash cam. Yesterday it did it again and I drove straight to the dealer since they hadn't seen it happen yet on another vehicle. They had me pull straight into the bay and plugged it, my IC is toast and new one was order yesterday and arrived this morning. Getting replaced on Tuesday.
lilgsx96
WA
I had the same issue (2019) with 850 miles on it but it was covered under warranty. the whole instrument Cluster was replaced. The part was on back order for a month. It the same part for some of the Mustangs and Expeditions, so you are fighting with them also.
Part number: KL3Z10849DBC (Instrument Cluster)
it kicked a code of: RO 759537 IPC internally failed
