Shark
After mounting Rigid duallys in the front bumper and Rigid SR-Q flush mounts in the rear bumper, I really wanted the large light bar for the upper grill but I just couldn't justify the price of the 40" bar from Rigid. A friend recommended Inspired Engineering lights and I purchased a 41.5" light bar for $531.00 after a discount code I found on the JK forum. I now see lights that look identical to this one (same specs, same mount, same housing) on Amazon from MicTuning and NadoTuning for under $300!
I mounted it up behind the same grill "bumpers" where the Rigid light bar mounts, although I had to fabricate my own brackets. I used some 4" x 4" aluminum angle cut to 1" width for the mounts. After a fair amount of time measuring, cutting, and drilling I was able to get the brackets to fit. I sprayed them black with some BBQ grill paint I had on hand to make them look nice. The existing screws on the bumper were inserted into some pressed-in nylon nuts that didn't seem sturdy enough for me so I pulled those out and used some longer bolts, flat washers, and lock washers. I also had to trim a little bit of plastic from the housing on the front of the radiator to get the bar in place. I am very pleased with how it turned out - it's very sturdy and very bright!
