High beam wire color
Squid 3
Ipswich, MA
I need HELP from all you electronic gurus!!!!!
I'm trying to isolate the high beam wire so I can use it as a switch line for my 30" light bar. I want the thing to only work when the high beams and switch #4 are on.
I'll be running through a relay.
The Car Stereo Company
aka grumpy car stereo guy
here, on frf
i dont have any info on the highbeams, but this might help. the highbeam should be in here as well. otherwise take a power tester and go to one of your highbeams at the light
https://www.directechs.com/DirectWire/PrintPhotoNotesBox.aspx?VehicleID=26147&Item=head
---------- Post added at 05:59 PM ---------- Previous post was at 05:57 PM ----------
damn it. its password protected again. hold on......
---------- Post added at 06:01 PM ---------- Previous post was at 05:59 PM ----------
this?.....shit
these are a (-) signal but i hope you can use it to find your highbeams. most likely the highbeam will be a (-) as well.
shthpnz
Madurodam, Holland
@nosbusa:
Slightly off topic. As I want my parking lights to be switched on the moment I start the truck I was glad to see the picture of the back of the switch. But how can I use the parking light wire when that wire has a negative voltage?
Can you explain what the (minus) means?
here, on frf
what are you trying to wire up? in order to change the (-) negative trigger ( or ground) into a (+) positive trigger ( or 12 volts) you need to use a relay
Icecobra
Gilroy Garlic capital of the world
Hey Busa, thanks for the info on the grommet in the firewall ran a 4g wire directly from the battery to passengerside kick panel... I am ordering up a ditribution block to give me power points for the VHF GPS and anything else I can think of I want constant 12 volt.... I dont see anything for the high beam on 12volt.com I looked....
