HELP needed on locating the climate control fan module
JimT
Tulsa, OK
I have a '10 and my fan is stuck on high speed. every thing else works on the climate control, temp, what vent to direct air etc. but the fan will not change speeds. Where is this module located so I can see which item to buy, apparently there are 2 different ones avail for our trucks.
Thanks,
Jim T.
phydough
RenderIllustration.ashx
19E624 HVAC Blower Motor Control Unit, Electronic Dual Zone ATC A/C All Flow Thru Floor Consoles
The second one available is for non flow through consoles.
JimT
JimT
Tulsa, OK
Phydough do you know where on the vehicle the module is located? Thanks, Jim
---------- Post added at 12:05 AM ---------- Previous post was at 12:02 AM ----------
Not sure what you mean by flow thru floor consoles, I have the vents on the back side of the console. I have a '10 SCAB with all the bells and whistles. lol
xtela
I think it is located behind the glove box on the right. If you open and empty the glove box and then push in on both sides where the back stops are the glove box will drop all the way down and you will see it on the right.
From the 2014 service manual:
Item Part Number Description
1 — Blower motor speed control electrical connector (part of 18B518)
2 W701696 Blower motor speed control screw (2 required)
3 19E624 Blower motor speed control
Removal and Installation
Disconnect the blower motor speed control electrical connector.
Remove the 2 blower motor speed control screws.
Remove the blower motor speed control.
To install, reverse the removal procedure.
