jcl48
So to begin this thread:
I have previously install RPG Off-Road Stage 3 rear suspension system; Installed around November 2013. As of last week I receive another pack of goodies from the friends at RPG Off-Road.
Here is a Pic.
So the list goes like this:
Upper Control Arms 1.5" Bearings
Lower Control Arms 1.5" Bearings
Power Steering Reservoir
Steering Tie Rods
And to add to this list (but not in the picture) I also have other pack of goodies from the friends at SDHQ Off-road also, and the list is the following:
Full Set of Doubler plates + extended LCA's Bolts and nuts.
Abs and Vacuum guards
Stainless Kevlar Braided Brake Lines
Power Steering Cooler
And a Pack from Amazon for Motul 5.1 Brake Fluid.
Now the big question is:
The RPG LCA's as you can see in the picture are the ones for dual front shocks. Can anyone guide me where to weld onto the frame the top plates for the added secondary front shocks? If you can provide pictures I will greatly appreciate any help.
I won't be running dual shocks as of right now but probably in the near future. As of now I will be running stock Fox Shocks and upgrading to the 3.0 front coil overs and rears also in the near future.
Budget wise what other brand of secondary shocks can anyone suggest using before getting the Fox 3.0 bypass?
Sent from my SM-G900H using Tapatalk
Here is a Pic.
Steering Tie Rods
