Gas gauge - digital vs analog
RaptorEnthusiast
This evening my analog needle was near the "E" (gas light came on) while the digital "gallons used" was showing 30.8 indicating I still had (in theory) 5+ gallons left.
Up until now, the digital and analog had been pretty closely aligned along the way.
So when I filled up, the amount on the pump showed 31.8, which is well within the standard deviation of my past fill ups compared with the digital.
What has been more accurate for ya'll's fuel consumed......digital or analog?
Also should it be a concern that my analog was showing almost Empty when in actuality I still had over 4 gallons left in the tank?
TornadoRaptor
NY
Sorry but what does RR mean?
I filled up because the gas light came on, but it filled up at 31.8 gallons, which is well short of the 36 capacity. I would have expected it to fill around 34 or 35 gallons.
Typo.... I typed er
as in fill her up
Big fingers
Ruger
Northern Nevada
I am willing to bet that the digital figures are derived/calculated by the computer and the analog reading is from the float sensor in the fuel tank. One discrepancy does not necessarily a problem make, but if that discrepancy persists it may indicate that you have a software or firmware glitch in the ECU.
RaptorEnthusiast
RaptorEnthusiast
Thanks Ruger. I will also add that yesterday happened to be the day I switched to stock tune before I took it in to the dealership for oil change and tire rotation.
Then I switched it back to performance tune in the afternoon prior to filling it up. Could that affect the discrepancy?
Also generally, which should be more accurate? The computer derived or the floating sensor?
Thanks
David
Ruger
Northern Nevada
@raptorEnhusiast, run a cheap experiment. Take that tune off, return the truck to the factory tune, and then run it for a couple fill-ups to see if the two fuel indicators agree.
IF I'm right that the digital readout is calculated by the ECM, it's based on engine size, fuel tank size, ECM-recorded driving habits, elevation above sea level (air density) - everything the sensors send to the ECM. Sounds impressive, but it's calculated based on the ECM's software. If you want to know miles-to-empty, that's good info. BUT if you want to know how much fuel in gallons is in your tank, the float sensor measures that directly.
Ironhorse07
Central, MT
The light is for 'low fuel' not 'no fuel' usually that allows for about 40 miles of driving to find a gas station or about 4 -5 gallons. The light coming on with 1 gallon left is cutting it pretty close. I personally don't like to run that low of a level on a normal basis since the fuel pump uses the fuel in the tank for cooling purposes. A guy I work with has put 3 fuel pumps in 2 years in his wife's Expedition because she always runs on the bottom of the tank.
adeerchaser
ALWAYS carry, never tell
Home of the Crimson Tide
In my truck, the light usually does come on with about 40 miles left. While I don't normally run my truck that low, the few times I have, it has always had about 3 to 4 gallons left. Figure the low side 11 to 12 MPG, 3 to 4 gallons, yep bout right.
MTF
Celebration, Florida
The needle is more accurate to what's in the tank because it's reading the float level.
The light and miles left are computer generated, by the MPG readings.
On my 2010 1/2 the light and fuel stations on the Nav come on at 50 miles left.
Now if I'm getting 7.8 or 11.2 the needle well be in different spots.
