DezRaceSVT
If you guys are ever doing any type of work on the front of you trucks and wondering what the torques are this is where to look. All these Tq specs are from the dealer.
NM= Newton-meters
lb-ft= foot pounds
lb-in= inch pounds
Barke caliper anchor plate bolts: -----------250 nm -----184 lb-ft
Brake disc shield bolts: ---------------------17 nm -----150 lb-in
Lower arm forward and rearward nut: ------350 nm -----258 lb-ft
Lower ball joint nut: ----------------------150 nm -----111 lb-ft
Shock absorber lower nut: ----------------550 nm -----406 lb-ft
Shock absorber upper mount nut: ----------40 nm -----30 lb-ft
Shock rod nut: ----------------------------55 nm -----41 lb-ft
Stabilizer bar bracket nuts: ----------------55 nm -----41 lb-ft
Stabilizer bar link nuts: --------------------80 nm ----- 59 lb-ft
Tie-rod end nut: --------------------------115 nm -----85 lb-ft
Upper arm-to-frame nuts: -----------------150 nm -----111 lb-ft
Upper ball joint nut: -----------------------115 nm -----85 lb-ft
Wheel bearing and wheel hub bolts: --------175 nm -----129 lb-ft
Wheel speed sensor bolt: ------------------18 nm -----159 lb-in
Wheel speed sensor harness bracket bolt:-- 12 nm -----106 lb-in
NM= Newton-meters
lb-ft= foot pounds
lb-in= inch pounds
