GEN 1 Full size jack mounted in the bed
Jhollowell
Everett, wa
Has anyone mounted a full size floor jack (pro eagle or other) on the bedsides or in an orientation other than flat (wheels down)? I have a custom tire carrier mounted in the bed as close to the left side as possible and would like to mount a bracket to the carrier that holds the jack between the tire and the bedside. The issue is i don't know if i have enough space to position the jack flat so i'll have to turn it 90 degrees. Any issue with leaking hyd fluid or anything else i might not be thinking of?
