if you have a tune , will the reset still work?
I don't think you know what turbo lag is. Could you describe it and I'll explain what turbo lag actually is.
And the throttle response ford won't alter. That's part of the EPA controlled tune and cant be legally adjusted
I haven't been there that long, but I'd have to imagine this is at or near the very top of the dumbest things ever asked on FRF
You just need to make sure your turbo increaser is turned on. There's a button in the back passenger seat glove box.
Obviously you didn't get my attempt at "tongue in cheek" humor. Sorry to have made you waste your electrons responding...
Of course Ford isn't going to do anything!!! Even though the stock Gen2 is a somewhat dangerous sled in normal aggressive traffic situations unless you are pushing it pretty hard, they will work to upgrade fleet mpg standards at the expense of performance.
The turbo lag I can live with (it comes with the territory), but the poor throttle response in this vehicle will lead to wrecks. Kind of like automakers' original attempts at traction control. A body shop's dream...
Don't get me wrong, the GEN2 has great, smooth HP and torque response under hard driving conditions. Sport mode, lock out gears 7-10, use the paddle shifters and this truck rocks. Ran mine thru the paces in the mountains last weekend under the parameters above. Go on fast dirt BLM roads (CO and WY), lock out 6-10, take off traction control and have a ball!
I just have to be careful around town in Normal mode when pulling out into traffic or changing lanes on the freeway.
BTW: My understanding of turbo lag is the momentary delay in increased intake air flow due to the fact that upon acceleration demand, the engine has to build sufficient exhaust flow/pressure to spool up the turbo to gain full intake boost airflow/psi.
As a side note: Mercedes/AMG (and others) are working on some interesting solutions. AMG is converting to a 48 volt electrical system to drive an in-line intake booster pump ahead of the twin turbos. As you probably know, without a variable frequency drive, an electric motor is essentially instant on. The electric intake booster pump gives instant (perceived to the driver) boost and once the conventional turbo lag is passed, the electric boost shuts off. All occurs in milliseconds. Pretty cool pairing of hybrid/conventional technologies.
I hope you have a nice day.
---------- Post added at 05:58 PM ---------- Previous post was at 05:56 PM ----------
Where haven't you "been there"?
---------- Post added at 06:04 PM ---------- Previous post was at 05:58 PM ----------
Respectfully, I'm not sure that you fully understand your truck. My turbo increaser button is in the trunk, just to the right side of the trunk release. You might have been referring to the ***** presser button in the back passenger seat glove box.
Have you performed the throttle reset procedure as explained? This is all you need to do. It needs done every once in a while because of how it learns driving habits.
