GEN 2 Exhaust leak
RedPanda
Scottsdale, AZ
uploading video I took below
Cold start this morning and at idle, noticed and heard leaking underneath the truck. Coming from a portion of the exhaust, tried to get a video of it. Sounded like it was burning (bubbling) whatever fluid it was leaking. Didn't smell though and stopped after the engine warmed up (5 minutes). Thoughts? Concerns? Recommendations?
View attachment FullSizeRender.mov
Donmatteo
Santa Clarita / Coronado
Seems like the condensation in the exhaust is burning off. The exhaust also has weep holes for draining. Not sure you have anything to worry about but if you're concerned, a better video/audio might help or a visit to a dealer.
nikhsub1
Los Angeles
Get under there on a cold start and move you hands around the clamps - if there is a leak you will feel the air. Can also do the same when warm/hot but need to be careful not to burn yourself. The dripping you see is just condensation from a cold start. If there is a small leak they usually seal up when the exhaust gets hot due to expansion.
R
RedPanda
Scottsdale, AZ
Thanks! Appreciate the insight, I’m very green when it comes to mechanical knowledge but learning fast with everyone’s help.
I’m in AZ so hard to find a cold day right now but I’ll do it super early if I see it happen again.
Donmatteo
Cold start is when it sits for overnight and completely cools down. Cold start means the engine is cold and not warm from a recent start or a hot start where it's been running for a long time and it's up to temp.
