Dyno run today. Any recommendations?
whtrapta
Ostrich Wrangler
Bolivar/Springfield, MO
Its not going to matter since the computer freaks out anyway and turns it off. Run in tow haul, I did both and it really does give you a ton more power. 4th gear is closest to the 1:1
debate
NW Indiana
T/C all the way off. T/H on. Maybe airdown some?
Edit: some weight over the axle might help. Make a video for show & tell, lol.
whtrapta
Ostrich Wrangler
No need to lock the rear end. If you have m mode (2011) then yes use that. 4th gear. ORM wont work when the traction control realizes the front tires are stopped and the backs are hitting 100mph. I wanted to get numbers from every way (standard, tow/haul, and ORM) and it wont.
SPRSNK
I Void Warranties
Franklin, TN
Depends on the dyno. I have seen some Dynojets that they had to overinflate the tires because the truck was wider than the dyno.
Big Blue
Administrator
Staff member
Admin
USA
Be sure you have a full tank of quality 93 octane fuel.
