Droid
kglesq's Brother
- Joined
- Sep 25, 2010
- Posts
- 1,483
- Reaction score
- 753
I can avoid triggering engine shutoff if I hold only light pressure on the brake after coming to a stop. So if I'm going to be stopped for less than 30 seconds, I do that, but if I'm going to sit at a light for a couple minutes, I let it do its thing.
I find it still marginally annoying because the threshold is very low...you have to be *very* light on the brake.
I had a 2020 Gladiator as rental for a trip, and this technique worked much better in it, as it required quite a bit more pressure to trigger auto start/stop. I'd *love* to be able to change the engagement threshold for the Raptor to be the same as that Jeep.
I'm guessing this would be a PCM setting (e.g. requiring a tuner to figure it out) rather than something we can tweak in Forscan. And I'd be almost certain it's not a physical switch that can be adjusted. Anyone have an idea?
I don't want to disable auto start/stop permanently...I do like the feature if I'm going to sit for a minute or two, but don't want it for 30 seconds.
