rsike
I have a 2012 SCrew with factory nav. I upgraded the speakers and sub today and added 2 amps. The sound is great but there is a slight problem with the system and the installer is saying that’s the way it is and they can’t fix it. I’m assuming they are wrong or I would have heard about this before. The system does different things depending on the way I turn the truck off.
Scenario 1: Turn the truck off and do not open the doors.
The head unit stays on and then turns off when the doors open, just like before the upgrade. The amps turn off for about 3 to 4 sec. then they turn back on by themselves and stay on. They do not turn off when the door opens.
Scenario 2: Just like scenario 1 but I open the door prior to the amps turning themselves back on.
The head unit will stay on until the door opens and the amps do not turn back on.
Scenario 3: Open the doors prior to turning the truck off.
Head unit and amps turn off when you turn the key off as expected.
Hope that makes sense, any help would be appreciated.
