Anyone have a noise in their back seat?
melvimbe
I had/have a noise coming from the back seat area as well. I originally thought the rear window was loose, but it turned out that it was my bed cover.. The noise I was hearing was the corner of the cover hitting bed side wall. Tightening the bed cover up a bit fixes the issues, but it gets loose every now and then.
DFW
I also vote the sunroof. Had the exact same issue...put some silicon where the sunroof meets the roof and problem solved.
K223
Florida
So to jump in on this. It sounds like I have some noise coming from the sunroof. I can here light creaks what seems to be coming from above. It’s loudest in the a.m. when pulling off the driveway and here and there you may here a light creak. Rarely open the sunroof, but have performed the maintenance on it with greasing the seals and the mechanism, and rails.
Is there anything else to get in there and check? More grease internally?
Asdjonasd
Had similar issue when brought new truck home.
Thought it was the seatbelt.
It was the jack behind passenger side rear seat.
It was loosely secured. Tightened it up, noise gone.
