Any way to turn off Backup Beeper? permamently
JetDriver480
What backup beep are you talking about? The sensors when you get close to something?
wakko0o
I would keep them on. I can't count the amount of times the beep has saved me from tapping something. Switching views from mirrors to rear cam is all that takes for you to have a close call when backing up
gwpfan
If that could be done in ForScan then can one set it so it stays in Tow/Sport Mode or whatever was last selected?
butts182
Jupiter, FL
I turned of the beeper in my 2014 F150 because the ball on my hitch made the beeper go off every time I put the truck in reverse. It was VERY EASY. Put your parking brake on, put the truck in reverse close enough to something so that the beeper is going off, open door, and look underneath the dashboard for the small speaker. It should be above the brake pedal. Simply unclip the electrical connector from the speaker. Problem solved and you're welcome.
FYI - When you put it in reverse, you will no longer have the choice to turn off the noise. No worries though.
dlbb
so cal
just curious if the sensors still did the range after u did the disconnect? like green, yellow, red.
also that would probably disable the cross traffic sound also on our gen 2. and i actually like that feature.
butts182
Jupiter, FL
I remember that there were lines both before and after, but I don't recall if they were colored.
I didn't have to do this on my Raptor since I don't have to run a large raise hitch like I did on my '14 (it was lowered). I have an 801A so don't know if it messes up the cross traffic alarms.
