40" Rigid Install Help
RaptorScrew
Oronoco, MN
Ok, just put on my Wicked Performance Bolt-On Bumper and Rigid 40" Bar.
I need help with the wiring for the bar. As you can see the bar comes prewired with a toggle with Black,Blue,Red wires attached. How do I convert these to my Aux #1 switch?
swoop1156
USA
Red goes to whichever wire UNDER THE HOOD you prefer. I recommend RED.
Connect the wires BEHIND THE GLOVEBOX. Connect yellow to red.
Hook BLACK FROM THE LED to ground in the engine bay.
Done.
Search for a post that I made, I went into GREAT detail with Ducati.
RaptorScrew
RaptorScrew
Oronoco, MN
Thanx guys. I've got the pass-through wiring already complete. I decided to do all four switches when I set up the Backlit SVT Logo.
I just wanted to make sure I use the proper wires when connecting to the passthrough.
I have a red fused wire on this setup that goes to "POSITIVE" battery terminal.
I have Solitary Black wire that goes to "GROUND" - no problem
I have switch with red, blue and black wires that are hooked up to toggle.
Swoop, You recommend that I take the "RED" and hook to my pass-thru wire for AUX #1
...just to confirm the black and blue wires attached to the toggle become in-op and should be taped off and wrapped up.
Correct?
***Also, Aux #1 is Fuse #18 which is a 30 amp from factory. Rigid only requires a 20 amp for the 40" bar. Do I need to swap out with a 20 amp or can I leave the 30 amp in there?
swoop1156
USA
WHoa whoa! Nothing...NOTHING connects to the BATTERY! :(
Everything is already wired with the AUX switches. Read the thread posted by Hockster (thank you) and understand it!
RaptorScrew
RaptorScrew
Oronoco, MN
I stopped!!!! I will proceed no further until tomorrow! I've had a few already and apparently it's time to stop playing with my rig until I'm a little more FOCUSED! :peace:
I'll post more tomorrow. I'm going to sit back and admire what I've got for tonight and tackle the wiring tomorrow after reading the post.
Thanx!!!
swoop1156
USA
Cliff Notes:
Connect wires behind glove box, which you've done.
Hook red/black wires from light to corresponding wire in engine bay and also to the ground.
That's it! :)
RaptorScrew
RaptorScrew
Oronoco, MN
Cliff Notes:
That's it! :)
I appreciate your help.
Hopefully this will help me:
These are the two (Red and Black) that you're saying I use...
Not this red and black... All three of these were attached to the enclosed toggle switch from Rigid
And this just gets secured to the fender somewhere...
I may have had a few drinks but I can still operate a camera...
treypal
Lord of the Raptors
Riviera TX
Trace the two wires from the weatherpack connector to their first termination. The red will be the Relay, the black should be a grounding eye, if its not, then trace it to its termination and cut it off, and crimp on an eyelet. Cut the connector off the red and splice it into your AUX hookup. Then find a bolt to put the grounding eye behind.
RaptorScrew
RaptorScrew
Oronoco, MN
Thanx for the help but I don't have a clue what a "weatherpack connector" is . Hell I wouldn't know what that was sober...
