2021 Raptor 37 Fuel Range ?? Only 415 with full tank
R
RaptorCDH
This. Don't worry your Prius should get 550-570 MPG over 6 months (depending upon how you drive), but since worried about MPG I have a feeling not strong lol.
Fuel economy and range will not be accurate until at least the first 500 miles. The truck is basing the range off of its time idling between the plant and dealer lot, so it’s going to be artificially low.
Thank you for the information Fordtechone…wrong forum gttxrap for discussing your love of Prius.
wheelman55
Big Bend or MN
Hi - it’s the first tank of gas ….I’ve only driven 80 miles. Mostly highway. Fuel mpg is 12.5 per trip computer.
I will see. I topped it off with premium (which I use exclusively)—
I will run a couple of tanks and see what happens. I have visions that assembly line installed a 27 gallon tank by accident. Lol.
Don’t know what mileage the 37’s are supposed to get. Maybe a bit less than 35’s?
Reality is usually 1 mpg less than what the computer says. If you do the math, 11.5 times 36 gallons is pretty much right at 415 miles for the tank.
Let us know what actual mpg is after a few more tank fulls.
Enjoy that truck!
SurfRaptor
Newport Beach CA
What is the standard range on a 35” Gen 3? For some reason I remember seeing posts of close to 700 on the Gen 2’s but maybe it just wishful thinking as gas rises close to $5 here in CA
zer0bot
Tustin CA
I have heard 500 miles and I got close to that going to Utah and back, it was 150 today to fill up in Tustin
sixshooter_45
Arnold
Just filled up my Gen2 the other day, 389 miles to empty.
Lots of idling and on 3.3 miles to work so it's all relative.
Ifly4vamerica
3 tanks so far on my 37, average mpg for each fill-up was 15.3 mpg, I reset trip 1 each time. that's a mix of freeway and in town. It usually says 575 or so DTE when ful.
Raptor 2014
Well he probably only put in 30 - 32 gallons not 35. BUT
Sounds about right with a medium to heavy foot. When I off road I see an average of 8 to 9 MPH in a 2014 6.2L - 7000+ LBs with gear. 2W, 4WD, altitude, speed VS fun factor. Just depends upon conditions and how heavy your foot is.
