2020 collision assist help
blwn
Cincinnati, OH
Worst case you can disable the adaptive cruise with forscan:
M
Mmm
SoCal
Tried that but it doesnt work. Just put a wrench error on the dash. No luck
That information is very helpful. I appreciate your input on this!! I will inspect the bracket and CCM again. Is there any way to know if the ccm is sending info to the truck? When I took it off the bracket there did not appear to be any damage.
If the CCM is not communicating on the network there will be associated DTCs and typically additional error messages. ForScan has the ability to perform a network test to verify that the CCM is online.
Langhorne
CT
I had a situation where the cruise control collision warning etc was all messed up. My mechanic discovered that the wheel bearings were worn out and all the sensors went nuts, no promises but might be worth a look. Once changed everything was okay!!!
Beachlife
Padre Island
anyone ever figure out how to do this? We hit a coyote and damaged the front fender, we replaced the front fender but the C-CM module is tossing vertical alignment errors, tried clearing and resetting the errors but no dice, so rather than spending an arm and a leg troubleshooting something I don't use I'd rather disable it.
roush_14
Rhode Island
Has the windshield been replaced by any chance?, some of these systems use camera in there that work together. just a thought.
