2017 FORD RAPTOR CONTROL SWAY-A-WAY 3IN REAR BYPASS SHOCK KIT - 302-0058-02
$2,695.00
The 2017 Ford Raptor Control Sway-A-Way 3in Rear Bypass Shock Kit has giant 3.0" diameter triple bypass shocks that feature all the same race winning engineering and components that have 20+ years of testing, into a specifically designed kit that will bolt directly into your Raptor. This kit offers ultimate off-road performance without sacrificing any on-road comfort or handling. These rear shocks are 100% designed and built in the USA that features the bright zinc plated steel cylinder bodies and CNC machined aluminum components. This package is designed as a direct fit application and requires no modifications to the vehicle.
APPLICATION: 2017 FORD F-150 RAPTOR
![tor_control_sway-a-way_3in_rear_bypass_shock_kit_1.jpg tor_control_sway-a-way_3in_rear_bypass_shock_kit_1.jpg](https://www.fordraptorforum.com/data/attachments/262/262057-2d2367fbc406df9e3be8c28bc5b5a253.jpg)
https://www.southerncarparts.com/2017-ford-raptor-control-sway-a-way-3in-rear-bypass-shock-kit.html
$2,695.00
