2010-2011 spark plug wire retainer part#
Discussion in 'Ford Raptor Engine Discussion and Performance Mods' started by FITZ, Mar 7, 2014.
Sponsored By: GotExhaust
  1. FITZ
    FITZ Full Access Member
    287
    94
    Nov 13, 2013
    Momence, IL
    Does any one know what the part # for the 2010-2011 spark plug wire retaining clip is? The plastic part that holds the wire and is attached to the cam covers by thin little studs. Thanks!
  2. MTF
    MTF FRF Addict
    3,414
    851
    Nov 27, 2010
    NYC
    fordracing.com/parts
    Will have everything you need to find the # and or just order it.
    Right now the site is down!
  3. FITZ
    287
    94
    Nov 13, 2013
    Momence, IL
    I'm looking into putting the 2010-2011 ford racing cam covers on my truck which is a 2014. Looks like the only difference is how the spark plug wires attach to the cam covers and the wire loom that runs across the engine on both sides also use the same type of connector. Was just seeing if I can find the part numbers or if this is a no go. Thanks
  4. MTF
    MTF FRF Addict
    3,414
    851
    Nov 27, 2010
    NYC
    If you click on details they have a blowup with part #
  5. MTF
    MTF FRF Addict
    3,414
    851
    Nov 27, 2010
    NYC
  6. FITZ
    287
    94
    Nov 13, 2013
    Momence, IL
    Thanks for the help, My guess is that the clips come attached to the factory plug wires. So I would need to order new wires for this to work. Then I still have no way to attaché the wiring harness that runs across the top of the cam covers.... I'm thinking there might be an awesome set of Ruby Red 2010-2011 cam covers for sale soon. Would probably look good on a black truck
  7. BAJASVT
    BAJASVT Full Access Member
    982
    443
    Nov 7, 2011
    SE Michigan
    Are you looking for the actual studs or just the plastic retaining clips that thread on to the studs and hold the wires? There are three on the passenger side and four on the drivers side.
  8. MTF
    MTF FRF Addict
    3,414
    851
    Nov 27, 2010
    NYC
    Well there not Raptor specific just F-150, so maybe Junk yard?
  9. FITZ
    287
    94
    Nov 13, 2013
    Momence, IL
    Looking for just the plastic retaining clips that mount to the studs
  10. FITZ
    287
    94
    Nov 13, 2013
    Momence, IL
    It appears this isn't going to work. Looks like there going to the for sale section....Damn. Cause they look awesome.
Share This Page
