0365 Error Code
victorsam
2014 with 1900 miles. P0365 error code, Camshaft position sensor B, circuit bank 1. It has happened twice. I am wondering how common this has been on the 6.2. How serious is it, etcetera.
Any information would be helpful.
hosseface
Work
OK - I'm sure you know this, first off, it's going to be under warranty. You need the CEL on with the code in it and then take it to a Ford dealer.
I have never seen this on a Raptor before but I have on a regular 6.2. It is most likely the camshaft sensor itself. Other possibilities are a PCM, damaged camshaft or a small possibility of a broken wire or loose connection.
It is very important and needs to be addressed ASAP.
