Help a Noob Out
Raptor_man
Michigan *******
I want to grab some new rubbers and maybe rims but I'm really bad at this stuff.
I've got a 2013 screw.
What size are the stock rims?
What size are the stock tires?
How tick are the stock tires?
Whats the max size tire and rim I can put under the stock fender-flares at mid perch?
If I get larger tires, will I need a tune?
Finally, based on how I drive and what I'm looking for, what size tires and rims do you recommend?:
I want a wider and taller looking stance than the stock look.
I mostly drive casually (highway, etc.).
I don't want to throw a ton of rocks at my truck.
Any help in answering these questions is appreciated!
SVTLOPEZ
315/70/17 are stock tires. You can run a 35 with no trimming on mid perch. If u go 37 you'll need to do some trimming from what I've read on other post here on the forum. You won't need a tune from what I've read but if u go bigger than 37 you'll want to change gear ratios (Rzr owned). Everyone here including myself run method nv's with 315 or 35/70/17. I'd stick with a 35 if u do mostly highway driving and still want to have a fun good time
In the trails and mud. Next tire I get is either nitto trail grapplers or bfs koII
Hopefully helped a bit. There's a ton of forums on stuff like you're asking. Just hit the search button
Raptor_man
Raptor_man
Michigan *******
Thanks fellas.
What "type" of tire should I get if I want something mean looking?
It would be for mostly road driving and I don't want them to pick up a ton of rocks.
CoronaRaptor
CANADA
Thanks fellas.
If you don't want to pick up small rocks, then get tires with a lot of space between the tread, but remember, the more "gap", the more road noise!
HORN HIGH ACES
Colorado
HEAVYDUTY
Hey guys,
I'm a wheel noobie when it comes to this stuff. I have a basically new tuxedo black screw with stock wheels and tires (17 x 8.5. Tires are LT315/70R17).
I am interested in getting rockstar xd rims. However they don't make a 17 x 8.5? Would a 17 x 8 fit on the stock BFG tires?
Here's one that i found.
http://www.ebay.com/itm/17-Inch-Bla...ash=item36040f5ef9:g:JuoAAOSwnDZT8f6g&vxp=mtr
can somebody help me out and explain this?
Backinblack
Vancouver, B.C
Hey guys,
17 inch Black Rims Wheels Ford F150 F150 Expedition 6x135 Lug XD Series Rockstar | eBay
Friends don't let friends buy Rockstar rims. Method, KMC, Fuel and others offer a wide choice of styles. Nice hijack btw.
