Wiring harness re-route
Yukon Joe
Russellville, AR
Thanks for the write up KaiserM715. Orangeaddict and I did this on three trucks on Sunday. Took about an hour total. I didn't think it would be so easy. It isn't really a reroute, but more of a relocation. I should have done this many runs ago!
Anyone going to Havoc or Raptoberfest should take the 20 minutes and do this mod. Be sure to have a handful of good black zip ties before you start.
Yukon Joe
www.RUNRAPTORRUN.com
aka grumpy car stereo guy
drivers side wire harness
i want to make a serious point here. @manny had us install some bed lights in his truck a while back. he recently went on an offroad run with some other members. unfortunately he was unlucky enough to get a flat tire during the night portion of the run. he went to open the bed and his bedlights did not turn on. luckily there were extra flashlights around to help him get his tire and tools out of the bed of his truck. but the reason for this post is because after his truck came back to my shop, it took us a while to find the problem as to why the bedlights wouldnt come on. he had crushed his wire harness on the drivers side. the spot where it hangs below the frame. since we ran the wires with the oem harness, it was also in harms way. he was lucky though, imagine being in the middle of the night, middle of nowhere, truck wont start, and no place to get help for miles. the bedlight wires took the hit and luckily not the main harness. even if one wire is broken there, your truck will die and not start. i witnessed this in texas last year at trr as well @treypal came and asked me if i could help with a truck not starting. it turned out that that person was on the track the night before and his truck stalled. he had to get a tow off the course and a ride back to camp. the next day i went up there and spent an hour and a half trying to find the problem. he had crushed his harness on a rocky section of the track. 4 wires were broken and his truck just died. luckily i was able to find the problem and get the truck fixed. this is more of a reminder that if you are going to offroad the truck, please relocate the wire harness it takes just a couple minutes and will avoid an unwanted disaster. i took a couple pics of my harness. its nothing fancy. it just needs to work. you can relocate any way you want, but i found a simple couple strong zip ties and its out of the way. dont mind the mud under there.
AbnMP13
Mississippi
Is that at the front or back of the cab?
2014 Terrain SuperCrew
Vortex Mud Guards ~ Husky Floor Liners ~ Rigid Dually Flushmounts ~ Rigid Dually Clear & Amber Fogs ~ Recon Smoked Mirror Lights ~ Bakflip FiberMax & BakBox ~ SVC Tune ~ Rigid 20" E2 Series - Combo ~ Mid Perch ~ Underhood & Bedlights by Noah
dhollist
SE Michigan
After careful relocation:
You DO need to be careful not to place the harness where it will get pinched between the cab and frame when you land a jump. There is a good sized gap when the truck is parked, and it is tempting to route the wiring through there, but when the frame flexes or you land a jump, the compliant body mounts let the frame move independently from the body structure. In those instances, the gap might get small enough to pinch the harness and sever a wire.
I removed the second white Christmas tree fastener (from where the harness exits the engine bay), then replaced it with the one from the third position, but relocated it rearward by 1-3/4", then used a spring steel harness clip to attach it to the off-frame body mount bracket.
Sticky anyone? [emoji13]
All the best,
Dave
