Remote Start not working on Whippled Raptor
Fred
Richmond, VA
Tried the above procedure and no luck, should be some way to reset it.
H
you tried your second fob yet?
Check this:
on the Gauge Cluster there is SETTINGS:
  1. Under settings is VEHICLE
  2. Under Vehicle is REMOTE START
  3. There are three options to set, make sure the run duration is not set to OFF. I have mine set to 10 minutes to run
If they does not work:
  2. Vehicle is VEHICLE RESET.
  3. Try that
One thing i noticed is when you lock the doors, hit the lock button on the fob 2x (the horn will chirp)...now hit the remote start button 2x fast. DON'T GIVE IT A PAUSE BETWEEN EACH TAP.
See what that does, if nothing PM me and We can chat over the phone and work it out.
Fred
NickPic83
Rockland County NY
Do u have a check engine light on? I know with tunes u need to have the nuisance codes shut off or it will not let certain things like this work and throw a code. All tuners do it buy maybe they forgot. But if u dont have a CEL on its not that then.
Sent from my DROID RAZR using Tapatalk 2
Papi4baby
MD
Well if it was working before the supercharger, then that should be your problem.
Go to the dealer who did the install and tell them to fix it.
CB17
MN
I'm stock as well but had my first issue with remote start the other day which failed to start it. I started the truck with the key in ignition, turned it off, locked it up then started it with the remote. Don't know if that reset something but now it seems to work!
C
Cubdriver
Anchorage, Alaska
Well, i assume it worked before the install, i had not used it since the winter and i installed the Whipple myself in July. If its the Whipple its in the PCM reprogram, i have asked other whipple owners if they have this problem and no one else has said anything one way or the other.
H
Fred
Richmond, VA
This is out of nowhere...but have you asked Whipple if they disable the remote start? Maybe some safety feature? I don't know...but I could have never worked correctly, based on your post...
If it were me I would take it to an audio specialist and let them make sure everything is hooked up...
I thinking if it was working before...it is a safety thing and shut off in the tune...
Just spitballing....
MTF
Celebration, Florida
Give me a second, I will upload a video on Youtube to show how it should start.
Here you go
Whipple First Start of the Day - YouTube
Only push and hold a second then let go, one horn beep and and quick blink of running lights.
You will hear the doors lock!!!!!!! and then the H/E pump start then when all is good it will beep and horn again and then start.
Anything else you want me to look at for you Hank?
Question, can you hit the remote start while key in and ruuning and then remove the key. will it stay running?
If not, it's in the alarm/remote start you may have to reprogram the key fobs to the truck. It's a very simple step but I would have to look it up.
OK found the manual
blpp
Remote start won't work
Mines doing the same thing won't start the truck. ive reset before but it always goes back to not starting. I'm gong have it checked out at the dealer.
