Its not looking good boys...
someday
wisconsin
they still cant figure it out?
if everything has been changed in the front and it sounds like it coming from the bottom then its prolly a rod bearing so it will prolly need a rebuild or reman. if the front cover is still off might as well drop the plastic oil pan and inspect the lower end. maybe even do a compression test
5.0 swap?!
Donovan
DC
That website appears to be helpful. The one posted above, I will call them to see if it comes with the new aged cam phasers.
Donovan
DC
Alright - diag suggest bad crankshaft.
FKING DAMN IT.
1. Tear engine down and rebuild -$7k
2. Pay for used middle mileage 3.5 eco, $3-4k, $2500 to install, STILL 7k.
Thoughts? Anyone close to MD that can do the install for less than $2500 or have access to good used low mileage engines? If the engine is coming out what else should I consider?
MurderedOutSVT
Brodozin
Georgia
FKING DAMN IT.
Look at these guys:
