2020 suspension “squeal”
WNCgen2
North Carolina
Hey guys, I’ve noticed that when I have the wheel turned and hit small bumps and/or flex the suspension a little, I get a noise that sounds like the tire rubbing metal. Got underneath the truck and found no signs of rubbing. I’ve attached a video in hopes someone can help me diagnose this.
  • IMG_9419.mov
    12.5 MB
thatJeepguy
GA
Its not by a lot lol. You should hear 40’s on an xj cherokee pre fender trim…
thatJeepguy
GA
Sounds like scrub i think you’re over reacting . First truck with big tires ?
WNCgen2
WNCgen2
North Carolina
Checking the fender liners once again I found this on the passenger side:
I don’t know if this is related or if im just lucky enough to have discovered yet another issue with the truck
shigman
Cypress, TX
Not that it matters, but does it also do it in 4wd? Doesn't sound like anything related to 4wd, but its a quick test. Does it do it on all pavement types? Does it happen turning both left and right? I think what thatjeepguy is referring to isn't the tire rubbing on any component on the truck but a wide grippy tire making a noise when being turned at low speeds on the pavement.
