GEN3 Forscan
swoop1156
USA
I messed with it again
Now I have a the Blue high bean, the Green "A", but no White "A" I've checked everything 3 times.
Green A is what you want. Look above or previously on a page for where I explained (I think!) where a white A is auto high beams, green A is glare-free, blue light icon is std high beams.
Looks like you got it! What changes did you have to do?
JayRods
Manteca Ca
Can't wait to try it.
My wife and I went through each step one by one again. And comparing the rest of the code to my factory code from that other link. Some were not matching the full factory code. This is very stressful to be changing thing, hoping I don't screw anything up.
Thanks for all of your help.
swoop1156
USA
Excellent! Yeah, agreed. This is a lot to change at one time for one thing, but truly worth it. I really had to slow WAY down and go very detailed through it all.
G3Rap
Michigan
Is there anyway to use Forscan to increase the brightness of the three parking lights on the grill?
I’ve already forscan’d them to remain on for DRL’s but want them to be a bit brighter.
swoop1156
USA
I recall reading that it's not possible. I left my DRL's at factory so it's all match.
G3Rap
Michigan
My DRL’s are set to 75% right now. I think I’ll leave it as is for now.
I wonder if different LED’s can be swapped in. Hopefully there’ll be an aftermarket solution at some point
RGVRaptor
South Texas
I was told I could adjust the tire size and reset the zero on live valve shocks with the FORScan light app for iOS.
Is this true?
Hokiesean24
maryland
Can anyone give me the correct 2023 Raptor code for:
Disables door ajar chimeIPC720-01-02xx*xxx--see IPC spreadsheet to disable EIOCM
I really want to do this one but I am not sure excactly which code option is the right one.
Thanks!
ToadSmasher2K1
KC
Any advice on clearing DTC P160A:00-2F? I changed the front bumper and relocated ACC. Everything works fine but after about 15 miles it says Drive Module Fault, locks out suspension and drive modes.
The battery was disconnected for most of the day while doing the install, wondering if that has something to do with it.
PCM fault.
