fordfreek
L'Anse, MI
7" lift on 37s? Still looking at options for the OBS.
6" superlift with the extended radius arms. The 37" boggers would contact the fenders during harder off road. Put 36's back on it now.
If you're shopping lifts, go with extended radius arms. Moves the mounting points back near the trans crossmember to tie everything together for strength. Radius arm drop brackets will bend the frame if you off road it at all.
Nex
RIP CoronaRaptor
Washington State
Was looking at the shackle reversal kit from Sky Offroad and spring from OBS Solutions. Truck will be a mild tow rig. Off roading will be done in the Raptor. Not the OBS.
Rick at FMS
aka:Rick @ FreedomMotorsports
SW Virginia / SW Missouri
Been wanting to get these installed for some time. Tracks with movable mount rings. Just had to drill 5 holes per side. Did the passenger side first, wasn’t too bad. Then the drivers side was a different story. There is the shock mount above the frame that was smack in the way for two bolts. Got it done but a 30 minute job always seems to turn into a couple hours.
Alpine straps came in but just doesn’t work that great on two VP jugs. But also have a hunsacker and it worked near perfect.
Staff online
93,180
56,460
khunter
