Wiring cap third brake light
Jonesky
Louisville
FordTechOne
Detroit
The only circuit that can be used is CPB04 (VT/RD). It is capped off and taped to the harness in the driver’s side of the engine compartment near connector C1799, which is the connector for the brake vacuum sensor.
In order to prevent circuit overload or voltage back feed to the PCM, a relay and diode must be used.
pmariolo
PNW
Do you know if a 2017 has this wire?
