Anyone have a pic of 2019 OEM beadlocks setup as beadlocks?
Deleted member 17706
A true beadlock is a 2-piece wheel that literally clamps the outer bead of the tire to the wheel.
The forged beadlock wheel option on the Raptors allows you to do this when you buy a separate ring. You remove a trim ring, then you dismount the outer bead, install the new beadlock ring.
The pro’s are that you can’t roll a bead off. Which can happen running low pressure like at the sand dunes.
The cons are that you have to purchase it separately and they aren’t DOT legal. Technically. So no major tire shop will touch them.
So do you service your tires yourself? If not, who does them for you? I have always wanted to run them, but given how much I travel across the country, I think it would be a headache to find a shop that would touch them.
500mag
Georgia
Looks great. How are your fender flares all shiny?
93,171
56,440
jumpcutter
