Gas Can Hauling
Nick@Apollo-Optics
Intrigued. I have the rear builtrite racks already. how much for mounts / fuel cans?
You've got 2 options: RotopaX can, BuiltRight Mount, and RotopaX Locking Mount for $149 or RotopaX can, BuiltRight Mount and RotopaX Deluxe Mount for $129. Free shipping on both.
Love that set-up,but having the factory tailgate extender,just not gonna fit...my extender folds into where the gas can is....do they make something that goes against the front of the bed instead?
The mounts and all that would work on the front BuiltRight mounts, but the problem is clearance over the wheel well and it would probably stick up above the bed rail as well (if that was a concern). We'd need to confirm measurements before we did this setup at the front of the bed.
Now you have me looking for more stuff. These can be stacked, right ? Plus I see they make an empty one for first aid, tools, etc. hmm...
jabroni619
The secret is, get full length bungees like these: https://www.amazon.com/gp/product/B07M7KZX6B/?tag=fordraptorforum-20 run between the two rear tie downs and thru the can handles. I use this for gas, chlorine, and propane all the time. Works great.
That's what I do, unless I only have a couple jugs, then I simply fold my bed extender inside the bed and put them in the cargo area at the back of the bed, don't have much space to move around that way.
Nick@Apollo-Optics
Sadly it's only 2 gallon. I fill up 10 gallons on each trip.
You can stack a 3 gallon and 2 gallon together on each side of the bed. Total would be 10 gallons.
Yes they can. We can stock a 2 gallon and 3 gallon together on each panel to give you 5 gallons on one side.
And yes, 2 gallon storage packs are also available.
Ricoman
WASHINGTON STATE
Thanks Nick....really cant use anything that will go above the bed rails since I have a Tonn. cover,and looking for a mount that would maybe go against the back cab rather that sides....one piece along the back of cab....that fits below the rails,so I can still use my cover,BUT,when offroading,and cover is off,I can put gas/water cans....
I'll have to take a better look at the BuiltRite options...
CR Gittere
Charlotte
Nick@Apollo-Optics
Did you add rings to the bed bolts? https://www.fordraptorforum.com/threads/bed-bolt-tie-down-install.54540/
I use two rotopax 3 gallon gas and just ratchet them down to the bed between the rings. Built Right is great and all, but it would be like $300 to mount them on the sides of the truck.
That's a solid idea for mounting them and very secure. The whole purpose of the BuiltRight racks is to maximize space. The area under the bed rails usually ends up being dead space, but now you can keep it functional and helps keep things organized.
cool looking can. too bad it holds almost nothing
You can get a 3 gallon can in that location. But I get your point. The entire RotopaX line is about being compact.
If volume is your goal, we've got plenty of these 5 gallon cans from Holley for $40.
