JustRaptor1
Florida
Had the Corsa Cat Back exhaust with X-pipe res delete and gun metal tips installed. All I can says, is WOW, amazing. Big thanks to Roman with NEO Garage for the recommendation. I researched the heck out of all the available exhaust options, and while we can’t duplicate the Gen 1 6.2 sound, this one doesn’t sound half bad and no raspy rice cooker sound or droning noise in the cab, I couldn’t be happier. Only one bummer is, there was a nick on one of my exhaust tips when they unwrapped it, this will drive me crazy...side note, I got 3 different quotes from installers, all said, Corsa makes a very good high quality product.
Looks good! Do you have a sound clip you can post after installing the corsa.
Mbdurham
Georgia
Installed the Vaultek MX series twin pistol rack in my E&G console vault. They also have a single with 3 mag but the other pistol space holds mags just fine and I’ve got more flexibility this way. Took some work to get it in and had to trim one end but fits perfectly and still leaves storage space.
Vaultek Modular Non-Absorbent Foam Twin Pistol Rack (MX Series Pistol Rack) https://www.amazon.com/dp/B07BQM799H/?tag=fordraptorforum-20
45ba20d48d69a39b397daa7c4b89fd16.jpg12d1bea7f0e679a5e5e99eac659ce529.jpgc4bc2bd305860d75711531ff0c7d1c0c.jpg
dboat
Dallas, TX
Very cool
Sent from my LM-G820 using Tapatalk
dboat
Dallas, TX
Any issues getting the holder to stay put? Is it held in place with just friction?
Todd Turbo S
Nor Cal
WOW! I can definitely appreciate the attention to detail and thanks for the info on Nyalic. What lift are you using? Throwing around the idea of installing a scissor lift in my garage...
Congrats on the exhaust too! Corsa is a great brand for sure! Hopefully they exchange the damaged tip out for you since they aren't cheap to replace.
Hi. I’m not sure what brand the lift is, I used the one at my ceramic coating guys place. Yes, love the Corsa extreme, Apparently they will exchange the damaged tip.
Mbdurham
Georgia
It’s held in place by friction pretty tight as well as some 3M pads that were included that provide additional hold. It’s definitely not going anywhere. It was a squeeze (dead blow hammer) to get it through the top of the vault and it’s held tightly inside which is slight larger. It’s truly almost like they were made for each other [emoji16]
93,202
56,485
bjorn-dpc
