Phoenix Android Radio 4th Gen PX6
BIGDJE
OC, CALI
so for now i got android auto to work and use waze from tablet since i have no sync screen for now
questions is how do i adjust the gain for android auto? usually at vol 20 my stereo is blasting i can turn it to 30 max volume using tablet android auto and maybe 50 % of what is normal volume
BIGDJE
OC, CALI
found out its not just android auto but any audio from source on tablet the volume is very low maybe 50% or more then signal from sync i found some gains but they where already set to 30 and max is 35 still not enough
also what is the pw for when you hold down MCU upgrade screen its a diff pw then the Install Set code is 666888
i think there are more setting under that section
Gtibbot
Richmond, IN USA
Did you adjust the gains through the "Install Set" menu?
Password for "System Info" should be 7890
When I did the most recent update, when I started the truck. the output gain of both Sync & Tablet would slowly increase on its own to the highest volume. I was able to fix by going into "User Setting" > ACC Volume and changing to no save.
You might also play around with the Equalizer settings and see if that helps.
G.T.
BIGDJE
OC, CALI
yeah mine where all set to 30 i bumped them up to 35 which is max and still very low audio sound will have to keep messing with it ugh thx for password
G.T.
abearsfan
aldie, VA
So I got my unit the other day and it worked pretty much flawlessly right out of the box with my 802a 2019. tinkering around I have a few minor quirks
I implemented some of the procedures listed here in this thread (removed the speah app)but I cannot seem to get "ok google" to work, it worked at one point but not now.
Early in the thread someone mentioned to not use the included speaker; what do the red and black wires on the harness connect to? I get no sound/directions from google maps.
No sound from back-up sensors.
Opened doors do not always show or appear on screen, no big deal they appear on the dash.
I installed the autoboot app as well as the web car guru launcher. After startup, the console appears, then the launcher but it goes right back to the console? I may try Nova...
Is there a way to remove the index launcher completely, I hate that menu bar and only a few buttons are useful. Can you reprogram them to point to other apps?
What is the secret to pairing the wheel buttons under settings.
Gtibbot
Richmond, IN USA
"Ok Google" will only work with a Launcher that doesn't support it. I use Nova Launcher and it works fine
I installed the small included speaker, not sure if I have ever heard it though, could be that the Sony center channel speaker is drowning it out. Are you using Google Maps through Android Auto or just a stand alone app?
Sorry, can't help, I have seen other mentioned this as well, but mine work (2015 F150)
I believe only the built in launcher supports open doors showing on the screen
I'm using autoboot to go to the SYNC screen (what they call Console) and is working fine with Nova.
I possible could uninstall the index launcher, but that would not remove the top icons as they are hard coded into the system. The firmware I'm running now allows 3 or 4 of the icons to run another application, but I can't remember what those are
My came programmed from the factor and work like they should
93,202
56,485
bjorn-dpc
