Kahuna
THE MORE YOU PLAY WITH IT, THE BIGGER IT GETS
- Joined
- Aug 31, 2014
- Posts
- 870
- Reaction score
- 794
Ok, so we only need to un/reload the BCM module?That is better than the 10 or so I had imagined. Did you leave the other modules modified when you loaded your tune?
Yes, IPC Quick Boot (No Ford animation shows on cluster) was what I meant by splash.
BCM stuff on mine:
Auto start stop off
Double horn honk disable. (I also have push button, I mentioned key by habit!)
Panic alarm disabled (I have small kids)
Intrusion sensor enable (planning this)
Powerpoint timeout disabled
I think global window open/close is tied into BCM. From the spreadsheet...
Global Window Open/Close
BCM 726-17-01 0101 0101 014A
BCM 726-17-02 0101 0101 014B
BCM 726-30-01 0101 xxxx xxxx
DDM 740-05-01 Dxxx xx
PDM 741-05-01 Dxxx xx
I can do without most of these but some are a must. (DHH)
Intrusion sensor..? Thought it’s already active with our trucks—gives option when shutting down on the inst. panel..
Intrustion sensor is for the add-on shock sensor which needs to be enabled through Forscan after installing. The one mentioned in the inst. panel is the interior motion sensor.
And what about the inside... you familiar with that? is it real motion sensor? if so, what will set it off then? cause i couldn't get it to alarm without opening doorIt installs down by the pedals.
https://www.fordraptorforum.com/threads/oem-shock-sensor-security-system.61738/#post-1266738
Interesting.. will have to experiment again with it..I have had the kids set it off while inside but I have never really played with it.
