Venomrex 602 17" Wheel Sale - Buy 3 Get 1 Free!!!!
OffroadAlliance.com
OffroadAlliance.com
Boston, MA
These should not cause any rubbing if using the OEM tires (may contact mud flaps if you have those installed). If you're running larger than OEM, we typically suggest the addition of a perch collar or Geiser springs to help raise the nose of the truck up. We have quite a few RPG perch collars and some Geiser springs in stock right now as well.
Here's a few more images:
OffroadAlliance.com
OffroadAlliance.com
Boston, MA
What is the difference in coal black & mystic black? On the website it only has mystic black available. I know the coal black is satin, does that mean the mystic is gloss?
Venomrex considers both to be a satin finish. However the 601 and 602 series of wheels go through separate production lines so the exact sheen is different between the two.
Fury Road
New Jersey
Thanks, was thinking just put the stock tires on these and run factory wheel with snow tires for the winter. How do you like the bronze on a black truck?
tmanker
Midwest
Any issues with high-speed offroading with +12 offset and 1/2" wider wheel?, e.g. raptor run, baja run?
