GEN 2 HRE / R1 Racing BBK installed and review
Jayrod
Jayrod
FL
Did your shop weigh the OEM vs R brakes and can we get a side shot from far away, need to admire the wheel ****
I'll have more photos Friday. Yes they did will get all that for you.
gryGhst17
35x12.50x20
20x10 TR46
Simple math:
35" tire - 20" rim leaves 15"/2 means you have a sidewall of 7.5, where the stock would have 9". How's the ride compare?
I'm running stock and mine gets a bit skiddish over road bumps even after I lowered the pressure to 38psi.
Jayrod
Jayrod
FL
Simple math:
Ride is pretty much like stock. I noticed just a tiny bit more noise at higher speeds on the interstate but normal cruising I can't tell the difference at all. I'm running the 39 PSI. Had 41 on stock never did drop it down.
---------- Post added at 07:09 AM ---------- Previous post was at 07:07 AM ----------
Wheels look nice. It would be cool if they made 17s or 18s.
I want to say HRE just released a statement that said they were doing the 161 in 18".
Chris@FreedomMotorsports
FRF Gofur
Woodlawn, Virginia
Too bad they don't make one that fits stock wheels. I don't want 20's.
You guys are in luck. #1. R1Concepts does offer a BBK to fit 17" wheels and up. The kit that fits 17's has 6 piston calipers up front and 4 piston calipers in the rear, 345mm one or two piece rotors, your choice of rotor hat and caliper color (about 32 different color combinations).
For those that don't want to wait, I can help you now to get your order started. For those that are skiddish about the kit, I have the 17" wheel kit on order for my 2014 Raptor as we speak, although it may be another 3 weeks or so before it arrives for installation and review.
FRF Gofur
Woodlawn, Virginia
price for 17 " wheels set up?
The retail price for the kit to fit 17" wheels is $4352 plus shipping.
How much do these run?
Price depends on the size of the kit/rims being purchased.
Here is a break down of the retail prices for the kits available.
Front:
17" wheels - 345mm(12.99") 6 Piston - $2183
18" wheels - 356mm(14.02") 6 Piston - $2453
19-20" wheels - 380mm(14.96") 8 Piston - $3150
20" and up wheels - 405mm(15.94") 8 Piston - $3269 (NOTE: The 405mm rotor size is a tight fit on 20's)
Rear:
17" wheels - 345mm(13.58") 4 Piston - $2169
18' wheels - 356mm(14.02") 4 Piston - $2237
18" wheels - 356mm(14.02") 6 Piston - $2322
19" wheels - 365mm(14.37") 6 Piston - $2406
20" and up wheels - 380mm(14.96") 6 Piston - $2497
Retail prices do not normally include shipping if ordered directly from R1Concepts.
93,411
56,694
forcefed23
