2017 Raptor Sound System Build
mcasseba
I am nearing the finish of this over the top sound system install working with Noah from The Car Stereo Company, so I figured I would show some of the build process.
This is my third Raptor with a stereo upgrade and I feel this is the one. All of the install is completely custom and I did not drill a single hole throughout the process. Noah built all the custom bases and is in the process of molding a custom fiberglass box to house 2-10” Audiomobile Evo subs and one Mosconi amplifier.
I will post the final write up and install once its complete in a couple weeks. Noah needs to build the box and finally tune the system for perfection
Equipment
2 – 10” Audiomobile EVO subs
Mosconi AS300.2
Mosconi AS100.4
Mosconi Pico
Mosconi 6to8 DSP
Amp Pro Kit
K2 ES165 Speakers
K2 EC165 K Speakers
5 rolls of Focal Bam
2 Boxes of Black Hole Tiles
BBLV
Newport Beach
Curious on your choice of Audiomobile subs. I've never personally used them, just curious if you've heard them. I've only read not-so-good things about the company in the past...
Build is looking awesome, thanks for sharing pics.
WhatExit?
48th state
Looks like big buck$ for all the gear plus the custom work plus the installation. I hope it sounds incredible and it's worth the coin $pent.
Let us know how it sounds and if we can get something similar from Noah :)
M
mcasseba
Curious on your choice of Audiomobile subs. I've never personally used them, just curious if you've heard them. I've only read not-so-good things about the company in the past....
Yes, I had the GTS series in last truck and upgraded to Evo for this build. So far I think these are the best shallow sub since you only have 5" of mounting depth to work with. They hit hard with a nice level of output.
BBLV
Newport Beach
Have any details or pics of what and where you connected the factory harnesses to the PAC unit?
aka grumpy car stereo guy
i run 2 gts 10in in my truck with 950 watts. they are a much better sounding speaker than anything else that will fit under there without spending a lot more money. the speakers themselves are awesome speakers. the company however had some issues but never with product reliability. i actually dropped jl audio because these are a better speaker all around by far
M
mcasseba
It is a simple plug and play, it plugs right into two factory harnesses located on the factory radio/LCD and provides 6 inputs of RCA's. It mounts right behind the head unit.
BBLV
Newport Beach
Any way to output the factory center channel signal with this Pac unit?
Johngm45
Looks like I'm going to be in the same boat only running Hertz audio and a 7 day build time . Looking forward to matching the audio with the rest of the raptor
07480e71bda6b1db429a800dfdfb1870.jpgaa049766ea8c0eee918952da5ab374fb.jpg36367d27d85f9d8df351f52e06da2d7c.jpg
93,171
56,440
jumpcutter
