Lane Keep Assist Problems
ChevyChad
Anyone else getting errors with their lane keep assist? I have had 2 in the past couple weeks. The Ford Pass app says "The lane keeping system has detected either a system fault or an obstructed front camera". Under the 'What should I do' tab, it says to clean the windshield and move any accumulation of debris from the front camera.
I do not have any dirt or anything in front of the front camera, however, I should mention that both mornings that it happened, I did have dew on my windshield which I did wipe off with the wipers. Should I have sprayed some windshield washer fluid on to clear that off so that the front camera gets cleaned too?
kandewinn
Behind review on the windshield
The LKA module is located in that plastic housing behind you rear view mirror. Make sure the wipers are actually clearing away that area. If not, you may have to do it manually. LKA is not associated with your forward facing camera on the grill.
ChevyChad
ChevyChad
Thanks for that tidbit. I will check that out. I have went ahead and scheduled to bring the truck into the dealer for them to look at, but if there is something obvious that is obstructing it, I will just clear it myself and skip the dealer. Much appreciated.
ChevyChad
ChevyChad
Welp, nothing visable that i can see blocking the camera(s?).. Headed to the dealer soon.
alexny
Got the same error message on my 17 Raptor this morning; just curious if you found any issues with the camera at the dealer's on yours or its just a condensation ?
ChevyChad
ChevyChad
I took it to the dealer that day, but they could not get my truck in for 2 more weeks. So I made an appointment for 2 weeks after that, but the error has not occurred again since so I cancelled my appointment. My best guess is that it must have just been condensation.
alexny
Hope the same on my truck, just a weather related ..
Thanks for your reply!
BajaFred
It shouldn't be condensation
I've driven with crazy morning dew, torrential downpours and everything in between without the error
omar510
Hey hope I'm not thread jacking. How well does LKA work for those that have it? Wonder how well it keeps you in the middle of the lane
dlbb
so cal
i wonder about where it was parked when u got the error. i don't have lka but if i am too close to the wall behind my truck i get a blind spot error. ie was you parked close to a wall?
my bls works fine after i pull away from the wall.
