Fog Lights
Santino
Rochester NY
Hello everybody,it’s good to know there’s a lot of Raptor owners out there. I’m happy to a part of it. I have a 2019 Ruby Red it’s an amazing truck hands down. I want to add Fog Lights to the existing opening in the front bumper. Not sure which ones would look good. Can anyone give me a suggestion on what would look and work best.Thank You
melvimbe
I'd look over in the lighting forum and you'll see lots of options. Baja designs and rigid are probably the more popular options, but there are others. I imagine one of the many lighting vendors will be by shortly to tell you what they have to offer.
Frank R
clinton township Michigan
I added 3 rigid radiance amber back fogs on each side, wish I had a pic to show you, wired it up so I can run amber backs with running lights only(switch 6) and put lights on switch 1(15 amp) they(specialtyperformanceparts.com) have even brighter ones available, but these do just fine and no high beam flashing return drivers either
DFS
USA
I went with the Baja Designs unlimited kit and am thrilled with it. Throws a lot of light for what it is, fits well, and seems to be very stable.
eddro
Fayetteville North Carolina
I just installed Rigid radiance fog lights from specialty Performance parts. They were not cheap but look amazing . Took about 4 hours to install them myself on my 2019 . The company even post online videos that walk you through the entire installation process.
DarthKickA55
Tennessee
I did these:
Offroad Alliance Triple Bezel Fog Kit (No 3" Cube Lights)
Baja Designs S1 Wide Cornering (Amber) (Pair) / (3) Weatherpack Connections Wiring Harness
Baja Designs SAE Compliant Lights (Pair) Wide Cornering Lens
Baja Designs Squadron Pro LED Lights (Pair) - Squadron Pro (Driving/Combo, Clear)
They look like this:
I am happy with them - legal for on-road and a couple of higher power if I need it (non legal / SAE compliant).
OffroadAlliance.com
Boston, MA
Hey @Santino
We've got an absolute huge array of fog lights! We offer great options from Baja Designs, Rigid, KC, Vision X, Rough Country, Diode Dynamics, and more. We're sure to have a set that will work for you.
We even make a few in house mounts. Our bezel kits give you that OEM fit and finish (pictured below) and we make a highly adjustable mount that suspends up to three pairs of cube lights in the bumper openings. Both are stainless steel, built in the USA and designed to last!
Let us know if we can help!
PH ---->>>> 888-466-8991
Web ---->>> OFFROADALLIANCE.COM
Troutrad
Kalispell, MT
As above, check out the copious information available in the Lighting forum.
Lots of great vendor support. I like the Specialty Performance Products guys cuz not only do the have great support like a lot of vendors, and great products, they have some products unique to them and they have some of the best video instruction for newbies like me to doing mods. I did the round Rigid 360’s cuz I felt they filled the space better than some AND they have the amber backlighting so looks more integrated. Tons of choices and very few bad choices if you stick to the forum recommendations. Good luck.C8F228E8-1319-4CA2-9D35-21A7328B24F9.jpeg549AA731-AB64-46B6-8917-68CF3D76C688.jpeg6D6347F1-7623-4FA6-A6EF-0169C8512440.jpeg42C3BCD3-B3E3-46EA-9658-4E6C1E0C63B4.jpeg
TrewRaptor
Tucson AZ
I did the rigid kit with the drive, spot, and fog lights. I'm happy with it, took some time to adjust though. That being said I might lean towards a set that has them pre-arranged in the holders like above.
