Winch with rigid light bar
64auto
SouthEast TN
Looking for a winch plate and winch that will clear with a rigid light bar behind the grill. Using stock bumper afraid light bar will have to be moved. Any help would be greatly appreciated.
Yukon Joe
Trafford, PA
I have an outlaw winch mount, Recon 10,500 lb winch in the stock bumper and M&R 40" light bar behind the grill. Everything fits.
I think you will find that most combinations will fit.
Yukon Joe :baby: :baby:
H O L I D A Y CHEER Event fundraiser
Donate $10 for a chance to win a 50" light bar.
http://www.fordraptorforum.com/showthread.php?p=929496
oh, and if you have time, Submit your photo for the calendar contest
http://www.fordraptorforum.com/showthread.php?t=44744
64auto
SouthEast TN
Looking in to this. Any more ideas? Wonder about a warn winch? Always had those in the past
Yukon Joe
Trafford, PA
You can always adjust the hight of the light bar with different L brackets.
What is more important for you, light behind a grill which is cut by about 50%¿ or a winch used for recovery?
Get up with @RSiWORKS and buy the warn winch and winch plate. Then adjust the light bar as needed. It will be tight, but it will fit.
Be sure whatever winch you get doesn't have the control module mounted on the top.
saeuta
Holiday Cheer "Giving Back" Event. - FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor
Just get different brackets, my light bar is also M&R, I have the RC mount for F150s with a Warn Z12
I had to move the hood release handle an inch or 2
vecciomano
I have the SDHQ "behind the bumper mount", with the 5 ton Wern winch. Side lights wired to # 1 and #2 auxiliary switches, A light bar can be mounted behind the grill if needed. I will say the under stear has increased with this heavy setup. The two sidelights are very useful, but I am thinking of a removable light bar above the cab, for long night travels.
