Which Forscan
Merman
Houston
I am sure this has been discussed to death but I was having trouble finding the answer. I have a 2020 802A and looking for which Forscan tool to buy. Which one is the one to get or which is most popular?
blwn
Cincinnati, OH
Check https://forscan.org/home.html for the supported adapters.
Like mentioned above OBDLink are some of the best, but not the cheapest. If you're an IOS/Android user you might want to consider the MX+ so you can use Forscan Lite if needed to pull codes etc
Merman
Merman
Houston
Thanks guys! Got one ordered. Hopefully now i can figure out why my screen goes black from time to time.
blwn
Cincinnati, OH
If you're talking about the sync screen, make sure you update it to the latest version. There was a version with a bug that would use up all the disk space and cause it to crash
Merman
Merman
Houston
Good to know, thanks!
FatBuoy
In addition to the adapter question, which version of Forscan enables you to customize settings and reset the TCM? Will the Lite version do it?
