DEARBORN, Mich., Feb. 3, 2021 –Ford, America’s truck leader, created an off-road icon in 2009 when it introduced the desert racing-inspired F-150 Raptor. It was designed to not only speed over rough terrain, but also to jump and catch air.
And today, it’s born again with an all-new third-generation F-150 Raptor that takes the mechanical and technical brilliance and precision of Raptor and infuses it with enhanced connected technology that means the experience of owning one will only improve over time.
“Raptor is the original desert truck. We just took it to another level,” said Ali Jammoul, Ford Performance vehicle program director. “The all-new Raptor splices high-speed off-road performance muscle with advanced technology and connectivity that comes together in a unique Built Ford Tough way.”
F-150 Raptor has eclipsed the sales of other well-known performance icons. Over the last four years, the previous-generation Raptor cumulatively outsold Porsche’s entire lineup of sports cars and also outsold Chevrolet’s Corvette.
High-performance hardware
A high-performance off-road pickup is defined by its suspension, and the all-new F-150 Raptor debuts with completely redesigned running gear. It is reengineered with an all-new five-link rear suspension developed specifically for Raptor, designed to deliver more control and power to the ground with greater confidence over rough terrain at high speeds.
“Raptor is rooted in Baja 1000 racing, and its suspension advances our capability and performance – a five-link rear setup with more wheel travel than any Raptor before it,” said Carl Widmann, Ford Performance chief engineer. “And like a trophy truck, every aspect of Raptor has been engineered to deliver precision capability when your foot is flat on the floor, way out in the middle of nowhere roaring across the desert.”
The five-link rear suspension features extra-long trailing arms to better maintain axle position on rough terrain, a Panhard rod and 24-inch coil springs – the longest in the class*. The suspension design combined with more sophisticated engine management software means the truck can put more torque to the rear wheels for quicker starts off the line, faster acceleration and better throttle responsiveness while simultaneously delivering comfort, stability, handling, control and traction at speed.
Soaking up giant whoops and landings comes courtesy of next-generation FOX™ Live Valve™ internal bypass shocks with state-of-the-art electronic control technology offering position-sensitive damping adjustability. Raptor’s largest-ever shocks are designed to better resist heat buildup and to react even faster to terrain changes for greater confidence over extended desert running. The larger 3.1-inch-diameter anodized aluminum shock bodies are filled with all-new low-friction shock fluid specially designed to decrease frictional losses inside the damper for improved off and on-road comfort. New electronically controlled base valves are race-proven with an upgraded design enabling upward of 1,000 pounds of damping per corner at desert speeds.
Readings from suspension height sensors and other sensors around the truck change damping rates independently at each corner 500 times per second, with the shocks responding at the same speed the human brain processes visual information. The truck responds by the time the driver even registers a terrain change.
For the first time, Raptor is available with either 35-inch or 37-inch tires – the largest factory-fitted to a production light-duty full-size pickup. These specially designed BFGoodrich All-Terrain T/A KO2 tires offer maximum traction and handling. Wearing 35-inch tires, Raptor clears 12-inch obstacles with an approach angle of 31 degrees, maximum departure angle of 23.9 degrees and breakover angle of 22.7 degrees. Raptor with 37-inch tires features 13.1 inches of running clearance, 33.1 degrees of approach angle, a maximum 24.9 degrees of departure angle and 24.4 degrees of breakover angle. Desert runners and rock crawlers alike will appreciate the outstanding wheel travel with 35-inch tires, reaching 14 inches at the front and 15 inches at the rear – 25 percent more travel than the first-generation Raptor.
Available in SuperCrew configuration on a 145-inch wheelbase, Raptor features a fully boxed high-strength steel frame with a high-strength, military-grade, aluminum alloy and composite body. The more capable suspension, stronger, taller shock towers and rear control arm mounting points serve to withstand punishing off-road use.
The all-new Raptor is equipped with a third-generation twin-turbo 3.5-liter EcoBoost® high-output engine delivering torque low in the rev range right where it counts. It features
Raptor Audio FIle (MP3)
* Class is full-size pickups under 8,500 pounds GVWR.
** Trail 1-Pedal Drive is an extra driving aid. It does not replace the driver’s attention and judgment, or the need to apply the brakes. See owner’s manual for details and limitations.
Ɨ Range calculation based on 34.9 gallons (actual tank size 36 gallons) and a projected EPA-estimated rating of at least 15 mpg combined. Actual range will vary.
About Ford Motor Company
Ford Motor Company (NYSE: F) is a global company based in Dearborn, Michigan. The company designs, manufactures, markets and services a full line of Ford cars, trucks, SUVs, electrified vehicles and Lincoln luxury vehicles, provides financial services through Ford Motor Credit Company and is pursuing leadership positions in electrification; mobility solutions, including self-driving services; and connected services. Ford employs approximately 187,000 people worldwide. For more information regarding Ford, its products and Ford Motor Credit Company, please visit
corporate.ford.com.
Related Photos
2021 Ford F-150 Raptor
Feb 3, 2021
Feb 3, 2021
Feb 3, 2021
Feb 3, 2021
Feb 3, 2021
Jan 22, 2021
View More
Related Videos
![image.jpg image.jpg](https://www.fordraptorforum.com/data/attachments/296/296338-29c62cd954b15c0435430c8a852cf874.jpg)
2021 Ford F-150 Raptor Running B-Roll
Feb 3, 2021
![image.jpg image.jpg](https://www.fordraptorforum.com/data/attachments/296/296339-8a08ca822304a583a21eddb3e9e3916e.jpg)
2021 Ford F-150 Raptor Running B-Roll (sound)
Feb 3, 2021
![image.jpg image.jpg](https://www.fordraptorforum.com/data/attachments/296/296340-fae6d206c90c5b1dcc5c347db5212ed0.jpg)
2021 F-150 Raptor Interior and Static B-Roll
Feb 3, 2021
![image.jpg image.jpg](https://www.fordraptorforum.com/data/attachments/296/296341-830f6ec425d60be7450ee3bbd8ce968d.jpg)
2021 Ford F-150 Raptor Shock Animation
Feb 3, 2021
Design Sketches
Raptor Design Sketch
Feb 3, 2021
Feb 3, 2021
View More
PDFS
![cq5dam.web.374.210.jpg cq5dam.web.374.210.jpg](https://www.fordraptorforum.com/data/attachments/296/296344-037afe00380074fcdd4eb36aa613ede7.jpg)
Raptor Tech Specs
![cq5dam.web.374.210.jpg cq5dam.web.374.210.jpg](https://www.fordraptorforum.com/data/attachments/296/296345-0a768195108d783139c528442bd1c873.jpg)
Raptor Enhanced Exhaust
GIFs
2021 F-150 Raptor GIF
Feb 3, 2021
Feb 3, 2021
View More
FOX™ shocks
