Transfer case Oil
Discussion in 'Ford Raptor Maintenance Forum' started by medic701, Oct 8, 2016.
  1. medic701
    medic701 Member
    17
    11
    Sep 17, 2016
    What oil do I use for the transfer case. I understand that the transmission uses ATF LV,
    running a 2010 raptor 6 Speed Auto
  2. Ruger
    Ruger FRF Addict
    6,094
    4,487
    May 16, 2011
    Northern Nevada
    Ford specifies its proprietary transfer case lubricant and has never published its specifications. Given that, the safe bet is to go to the Ford parts counter and buy a quart. That's what I did.
  3. Chris@FreedomMotorsports
    [email protected] FRF Gofur Supporting Vendor Supporting Member
    45
    3,035
    2,495
    Oct 4, 2012
    Woodlawn, Virginia
    This^^^ in part. SOME of the transfer cases require Ford Specific T-case fluid and SOME require Mercon V. According to my Ford sources, n easy way to tell which one yours requires is to look for the Ford oval logo stamped into the side of the T-case. If it does have that then it requires the Ford specific fluid, if not it requires Mercon V transmission fluid. Now, whether I was told correctly on that part of identifying that, I honestly don't know. But I do know that my 2011 Raptor T-cse required Mercon V while my 2014 Raptor requires the Ford specific fluid. The best thing to do is go to a Ford dealer parts department and have them run your VIN number to narrow down which one your specific truck requires.
  4. medic701
    medic701 Member
    17
    11
    Sep 17, 2016
    Ok ill check it out and call them.
  5. Humvee21
    Humvee21 FRF Addict
    26
    4,839
    526
    Aug 17, 2011
  6. Ruger
    Ruger FRF Addict
    6,094
    4,487
    May 16, 2011
    Northern Nevada
    I have a 2011 and my owner's manual said to use Ford Transfer Case Fluid, so that's what I used. I have never had reason to distrust a vehicle's owner's manual until just now. Chris, are you dead certain about this?
  7. Chris@FreedomMotorsports
    45
    3,035
    2,495
    Oct 4, 2012
    Woodlawn, Virginia
    I am indeed certain about this. I found out about this when I needed to service my 2011 and was in for TSB service of the drive shaft pinion yoke a few years ago and this was explained to me by the Ford Master tech doing the service on my Raptor.
  8. Ruger
    Ruger FRF Addict
    6,094
    4,487
    May 16, 2011
    Northern Nevada
  9. Chris@FreedomMotorsports
    45
    3,035
    2,495
    Oct 4, 2012
    Woodlawn, Virginia
  10. ogdobber
    ogdobber Full Access Member
    708
    581
    Feb 9, 2017
    I kinda think its just a case of developing a better job specific oil over the years. There is nothing special in the tc (like clutch plates etc) Mercon v works...but the t-case oil lasts longer
Share This Page
