Tranny fluid leaking?
killswitch engage
Earth
I noticed after a drive yesterday that there is red fluid (tranny?) leaking on the very front of the frame rail on the drivers side.
It almost looks like it's leaking from somewhere by the rad corner.
Is there a tranny cooling line that runs there? I'm guessing from the deep red color it's transmission fluid. I noticed it when I lifted the hood and it's not farther back on the frame rail behind the radiator, just on the front and below the radiator corner.
Thanks.
EDIT: Think I just answered my own question. Found a picture showing the tranny coolant lines.
LONGISLANDRAPTOR
Long Island, NY
If its a deep red it most likely trans fluid. Get it on your fingers, if its real slimy and sticky its coolant.
just trace the lines if possible with a light and with your hands to find the leak.
K
killswitch engage
Earth
Just an update.
I should have looked up, waaaay up. It was the power steering fluid reservoir leaking at the bottom hose. Clamp was loose. New clamp, some fluid and I'm good to go.
Thanks guys!
